Backhoe Bucket shudder and loss of brakes...hydrolic prob?
   / Bucket shudder and loss of brakes...hydrolic prob? #1
Whitetail
Landenberg, PA
JD 410B 4x4
1984 John Deere 4x4 backhoe 410B with 5700+ hours....My question is; when it's already warm and you try to lift the front bucket there is a hesitation and shudder; and then it will lift. Also when you drive it on the road in "high" the brakes have to be pumped 1st in order for them to work - then work great (brake pressure gets lost for some reason). Could these 2 issues be related to a weak hydrolic pump?
   / Bucket shudder and loss of brakes...hydrolic prob? #2
Need to pump brake pedal could be master cylinder or final drive brake piston o-ring leakage.. On hyd shudder: how long since hyd filters were changed and ump screen cleaned?? Also recommend checking stand-by pressure.
John Deere Z994R (A50121)
John Deere Z994R...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2014 Genie GTH844 Telehandler (RIDE AND DRIVE) (A50774)
2014 Genie GTH844...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
