Bucket is damaged. Get new one or just bottom plate?
   / Bucket is damaged. Get new one or just bottom plate? #1
64 CASE 530
NORTHERN CALIFORNIA
64 CASE 530
The front bucket on my new to me 64 Case 530 is damaged. The bottom plate is bent under on one side which makes it impossible to set the bucket flat on the ground. It's difficult to pick stuff up cleanly. Should I try to find a used in good shape bucket or just replace the bottom plate? I suppose a metal worker could probably fix it.
   / Bucket is damaged. Get new one or just bottom plate? #2
Depends on how soon you want to use the loader. Check around for a good use bucket might take some time. Or take it to a welding shop have the damaged section cut out and replaced.
The choice is yours.
   / Bucket is damaged. Get new one or just bottom plate? #3
Fix it. Weld a new bottom over the old one.
   / Bucket is damaged. Get new one or just bottom plate? #4
The hand of man can set anew, that which he hath destroyed. Well most of the time anyway. At least when it comes to machinery. I say fix it. A photo would go a long way to helping reinforce that analysis. It is amazing what you can fix with the proper tools. What may look like a near impossible job to one person is probably a "no big deal, do it every day all day" kind of thing for someone else with tools and experience.
Thank You guys. I'll either take it to a shop or see if I have a neighbor with some welding skills.
   / Bucket is damaged. Get new one or just bottom plate? #6
buy a new one...there! you just wanted someone to tell you to buy a new so it don't feel as bad
   / Bucket is damaged. Get new one or just bottom plate? #7
Lots of wisdom there to buy a new one. Fixing with a new plate would do the trick but it won't "feel" as good as a new or gently used one. Keep your eyes open since a lot of buckets are interchangeable.
   / Bucket is damaged. Get new one or just bottom plate? #8
I have the blessing of having a really good local weld/fab shop. They could cut out the bent section, weld in a replacement, grind down the welds and repaint it and you would never know it was ever bent or even repaired. All at a pretty reasonable cost. Ask around at a heavy equipment operation near you who they would recommend. Heavy equipment (especially grading/clearing) needs repairs like this all the time.
   / Bucket is damaged. Get new one or just bottom plate? #9
Yup, just get out the old Bronson rock and pound it back into shape :)
   / Bucket is damaged. Get new one or just bottom plate? #10
I would probably use a large rose bud torch to heat the area and flatten it out. If it is really bad and thin I would cut a new bottom for it. Should be much cheaper than replacing the entire bucket. You can do a search for the bucket and see what comes up but shipping cost will likely be more than the cost of repairing the old one.
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
1997 JOHN DEERE 544G WHEEL LOADER (A52472)
1997 JOHN DEERE...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
