Bucket Hydraulics Won't Work
   / Bucket Hydraulics Won't Work #1
jackl
Bronze Member
Central New York
2013 Kubota B2920 364FEL and 5ft Bush Hog Finish Mower, 1952 Ford 8n, Cub Cadet
I have a ~1959 John Deere Diesel and was working the bucket when a log broke the hydraulic line. I repaired the line and added fluid, but the bucket won't dump. I can raise and lower the arms though. Is there a way to bleed the system? Any other advice?
thanks!
   / Bucket Hydraulics Won't Work #2
Full cycles of all hydraulics a few times should do it for you
Jim
   / Bucket Hydraulics Won't Work #3
It should still move with air in the system, it will just be sluggish as the air has to compress. Repeated cycles of the controls should purge the air back the the resovoir or thru the seals eventually. Do you hear the safety relieving when you work the bucket lever? If repeated full cycles of the controls don't work and the bucket still won't move, I would look for other damage from the log, such as a smashed/flattened hard line that is restricting the flow to the bucket cylinders.
I drove a wreck damaged vehicle home for a friend one time. It wasn't that badly damaged and we looked it over pretty good. All the main safety structures appeared to be functional and it looked reasonably safe to drive till I drove it. It had no right front brake and caused a pretty heavy steering wheel pull when braking hard. During the crash, a body structure had been deformed into the suspension and chopped a brake hardline right in two. This cut and crimped both ends of the hard line. They were perfectly sealed and dry with no brake fluid leakage. We played with it for quite a while and the crimp was strong enough that it would not leak even when repeatedly stomping on the brake pedal...
   / Bucket Hydraulics Won't Work #4
Check all hydraulic connectors and make sure they are solidly connected. (disconnect & reconnect)
David
   / Bucket Hydraulics Won't Work #5
If it won't purge out, I'd take the lines off to the dump/curl cyl and aim them in a bucket and run the valve back and forth to see if the spool is working. if it is, hookup one line only and run it to see if the cyl is bypassing thryu blown packing inthe ram.. etc.
Soundguy
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
2014 Doosan DA30 (A53472)
2014 Doosan DA30...
