Bucket grapple hydraulics help
   / Bucket grapple hydraulics help #1
fcoats
Grenada, MS
Kubota 6800
Not sure which form to post in but hope this will work.
I added a bucket grapple to my FEL on a M6800 Kubota. I used a diverter valve from Bailey http://baileynet.com/hydraulics/solenoid_valves it is a 12 V solenoid and the last on the page (220-934). It seems to be the same valve as Surplus Center did have. I can hear it click and see the light on it when it is energized.
I connected the valve using the curl valve from the FEL hydraulics. With the power off the curl functions as it should, and when the valve is activated thydraulic fluid goes to the grapple cylinder. When I activate the soleniod to control the grapple, the grapple cylinder does not work. Each line will pressurize, but the return flow does not go back to the tractor.
I have disconnected each line in turn at the front of the tractor and each will work the cylinder, as it should, but the hydraulic fluid is pouring out onto the ground. It acts like there is a check valve in each line that will only allow flow out ,but not back to the tractor.
I used standard 3/8 hose and ag couplers from Surplus Center. I have couplers at the FEL valve and at the front of the tractor. This is if I want to disconnect either the grapple (bucket) or FEL. To make sure I don't confuse the lines, I used a male and female at the value and front which will only connect to the opposite connector on the hose. Similar to a skid steer set up.
Do any of you have any ideas?
Thanks,
   / Bucket grapple hydraulics help #2
Check your couplers, I had the same problem years ago. I bought used couplers from Surplus Center and one of them had a blockage in it. Take them out and connect them together and try blowing thru them both ways. If they are okay you might have a blockage at one of the ports at your valves or cylinders, hopefully not inside the valve.
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2011 Honda Pilot EX SUV (A53117)
2011 Honda Pilot...
John Deere 5100M (A50123)
John Deere 5100M...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2019 Ford Fusion (A51694)
2019 Ford Fusion...
