gladehound
Veteran Member
Hi all,
I have another question about my tractor. The bucket curl is a little weaker than I would like. The lift is stronger than the curl If I burry the bucket in gravel with the bucket level. I often can't curl the bucket. I nearly always can lift the bucket. Unfortunately, lifting first causes more gravel to drop. Once the bucket is free of the pile, it curls with no problem.
I noticed on the bucket, there are two places where the cylinder end could be mounted. Mine is mounted on the spot closer to the pivot pin resulting in less force and more speed.
My question is, is there reason I shouldn't switch the cylinder to the other mounting holes to get more curl force
I realize it will be a little slower and that the range of motion may be less.
How hard is this to switch
Thanks.
Ron
Thanks.
Ron
