BUCKET CUTTING EDGE 7 ft.
   / BUCKET CUTTING EDGE 7 ft. #1
toolaholic
Have a full size Massey Ferguson T B L . Not a lot of dealers around Me . What is the steel used A R 400 ? should I weld to the bottom of existing edge? Thank's Tool
   / BUCKET CUTTING EDGE 7 ft. #2
AR 400 works good but another solution Ive used on my old hoe and a few others is to get a grader blade edge from the county. lots of times they are worn off and not flipped over in time to use the back edge. I just measure off the unused edge to the middle and mark my line. most of the time I have to replace the bowed bottom I cut the whole bottom out and fab a new one. I usually order 5 inch by 1/2 inch loader cutting edge. About 78 dollars for 5 or 6 feet from SSB on there web page. Its all flat and prebeveled. som grader edge is curved and causes the bucket to suck in the ground or pile so you have to watch for that if you use it. Dont let SSB try to sell you the weld on bucket corners they are just pieces of the edge that are cut off and weled on just order a few extra inches.
thank's taylor
New/Unused Quick Attach Post Driver (A51573)
New/Unused Quick...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
