Buck s470- can raise and lower lift arms by hand
   / Buck s470- can raise and lower lift arms by hand #1
PAVLOCK
TOMBALL
SATOH BUCK S470
Was working fine until pulled out of the mud. Now the lift is inoperable and the arms can be raised and lowered by hand with out resistance and rests at the lowest position. Never pulled the lift assembly apart yet but assuming a pin snapped etc. Would someone mind walking me through the R&R procedure?
Appreciate any help given.
Bryan.
   / Buck s470- can raise and lower lift arms by hand #2
I had the same issue on my s373d, my first step was to pull the cap off the end of the hydraulic ram which showed an empty tube, after looking at it puzzled for a few minutes decided that the piston had to be somewhere. So I pulled the lift arm assembly off of the frame to allow access to the rear differential area. I sifted through the oil and found the piston and the actuator rod laying in the bottom of the case. To reattach the actuator rod to the lift arm assembly you do need to remove the lift arms from the housing because there is not enough room to reinstall a cotter pin into that assembly when assembled. Put things back together in the reverse order and you should be set, assuming there was no collateral damage from the piston falling into the differential area i.e. hitting the teeth of the differential and damaging the piston seals.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
