Bubbling Around Injector
   / Bubbling Around Injector #1
RMEADOWS
Bronze Member
Lakeland, Fl
MF 1428
I went to fix my L245 this weekend and came about a snag. I have bubbling around the injector on the front cylinder. I went to tighten it but found the intake manifold in the way. I went to remove that I found the nuts for the injector lines on the pump were in the way. Finally got all that apart to find out I could not tighten it and figured the copper ring had gone bad per an early post.
I went to remove the injector to find out there is a nipple sticking out the side (fuel return?). This would not allow the injector to turn as the head cover is in the way. This is not coming off (it can't).
How do I get the injector off? Any suggestions? /forums/images/graemlins/confused.gif
Got the injector off. Ended up breaking the nipple and now I will be buying a new injector.
I got out my parts manual and found out how to get off the head cover but after I broke the nipple thinking it had to screw out (I was wrong /forums/images/graemlins/shocked.gif).
Wish me luck getting the new injector and gasket in!
Got it done!
Had to buy the nozzle for the fuel overflow but got it our and replaced the copper washer. All bubbling is gone.
After I did that I replaced the tube on the front tire, twice. Pinched it the first time.
Then I went to raise the rear of the bushhog and broke the bolt.
After 2 days of working on the tractor I finally got it going. Works like a charm and was able to cut the field with no problems. In fact, after I made all the adjustments I was able to cut the field with no bogging down and cut the field in record time.
Thanks for all the help in the past weeks on this.
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A53843)
GRID SHAPED BUCKET...
