Bubbles from the radiator
   / Bubbles from the radiator #1
coloscott
Conifer, CO
Massey Ferguson 65
Hello,
I'm doing volunteer maintenance on a Branson 3510i tractor for a local horse rescue ranch. They have been having overheating issues with it and after flushing the radiator today and running it with the radiator cap off I noticed it is blowing bubble out the radiator. Big bubbles at first and then with it warms up to operating temperature the bubble become fine and they never stop as long as the tractor is running. Is this a leaking head gasket?
Thanks in advance!
Scott in Colorado
   / Bubbles from the radiator #2
A leaky head gasket is probably the least expensive thing it's likely to be. It could be a cracked head or block, too. The engine could have overheated and done more damage but you can hope for the best. I'd probably start with the head gasket and hope for the best.
   / Bubbles from the radiator #3
If you pull the head be sure to have it magnafluxed to check for cracks.
   / Bubbles from the radiator #4
more than likely the head gasket is allowing air into the cooling system which is causing it to bubble up through the radiator, you could possibly have a cracked head especially with it having been overheating recently, i would definitely pull the head and do a dye test with magnaflux, i would also do a radiator pressure test if you have the ability to, you could be sucking air their but more than likely it will be at the head but it never hurts to check all your bases.
   / Bubbles from the radiator #5
I'd start with the head gasket. Usually the gasket will show you if/where the rupture occurred. Other thing, with the head removed to check the gasket, check the cylinders/head. Any water intrusion will spit shine that cylinder vs the rest of the engine.
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
New/Unused 7ft Stainless Steel Work Bench with 10 Drawers (A51573)
New/Unused 7ft...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
