BSPP question
   / BSPP question #1
davedj1
Veteran Member
Jackson, NY
Kubota L2501
I'm getting ready to order the 4-6 spool valve for my crane and Ebay has some that are lower cost but use the BSPP fitting, is it worth it to buy the valve and then buy a bunch of adapters (can be had for a couple bucks each)? Or just bite the bullet and buy one for 3 times more money that is SAE?
   / BSPP question #2
You will probably need adaptors to go from SAE to the hoses too. If it were me I'd be using all JIC hoses with adaptors to whatever is not JIC.
The expensive valve may be better in other ways however.
   / BSPP question #3
Should be able to get fittings that go from BSPP to JIC without to much trouble. More fittings equal more leak points so I try and use the least amount of fittings to get the job done.
What are the existing hose ends on your crane or is this a rebuild?
   / BSPP question #4
If you end up going the BSPP route, which is very common on this side of the pond, don't forget to the copper washers or bonded seals. Either one is fine. These fittings just rely on the washers to seal properly, no need for tape or any other type of sealant.
   / BSPP question
Thanks for the input guys.
It's going to be all new plumbing, I should have specified. I'm building a dump trailer that will have a crane on the tongue.
I can get the 5 spool valve off Ebay for $106, 4 spool for $88.00 vs a 4 spool on SC for $300
6 spool on SC is $425
6 spool on Ebay is $135
If I go with 6 spool I will have power outrigger and power leg.
   / BSPP question #6
That sounds almost too good to be true. Any links for those valves?
   / BSPP question #8
Wow. What a nice price for a Badesnost valve. Good valves but the internal leakage it's bit higher than the more expensive ones. I have one on my homemade backhoe, it has over 800 hours easily and it's been working perfectly. I converted it to joystick with my own design. I also have several single spool from the same manufacturer.
Does the shipping and custom costs still make it worth for you?
They do have some cool prices. I might bite the bullet and get an accumulator for a soft ride feature for the loader.
   / BSPP question #9
I've never seen such prices. I wonder what the story is? Just considering the fixed machining costs, that price doesn't leave much for people & materials.
rScotty
   / BSPP question #10
None of the important features such as load checks........
I do not know how important these would be on a crane but I think they would be if they are included in better loader valves
Dave M7040
UNUSED LANDHONOR GRABBER SCREEN SIFTER BUCKET (A50460)
UNUSED LANDHONOR...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A49346)
2025 Kivel 42in...
2015 Ford F-750 Truck, VIN # 3FRXF7FK4FV740779 (A48836)
2015 Ford F-750...
6 Yard Commercial Dumpster (A49346)
6 Yard Commercial...
Lull 644B-42 Highlander 6,000LB. 4x4 Rough Terrain Telehandler (A49346)
Lull 644B-42...
New/Unused 4ft Bush Hog BH114 Rotary Cutter (A48837)
New/Unused 4ft...
