BSC 749 and mowers experience
   / BSC 749 and mowers experience #1
Maine Hills
Bronze Member
Midcoast Maine
Kubota B2650 BCS 749 Kubota RTV X1120
This past spring we purchased a BCS 749 tractor with electric start Honda 13HP engine, optional 6.5x12 tires, and two pairs of wheel extensions. We also purchased a BCS duplex 59" sickle bar mower, and a Berta 34" flail mower. The tractor and sickle bar mower were purchased from Bradstreet Lawn and Garden in Brewer, Maine, and the flail mower was purchased from Earthtools. Both purchases went smoothly. The BCS tractor and mowers were purchased to mow the portions of a former pasture which are too steep or rough for me to mow with a four wheel tractor, and also mow every other year an acre of wild blueberry "barrens" which is currently inaccessible to a four wheel tractor. The former pasture is are on a hillside in Maine with grades up to twenty five percent, along smaller, steeper embankments, bumps and holes. The soil is full of rocks, and has numerous wet areas. Total area mowed so far this year is about five acres. The sickle bar mower was used for the most of the mowing which was grasses and similar vegetation from three to six feet tall in open spaces. The flail mower was used for clearing brush and mowing in more confined spaces, including the bottom of a drainage ditch. We have been very satisfied with the tractor and the mowers.
We decided we wanted three working speeds, differential, individual wheel brakes, and an engine powerful enough for the 34" flail mower and the 59" sickle bar mower. A fourth "transport" speed was not a consideration for us as the land is steeper than I'd want to ride behind the tractor on a cart or sulky. That narrowed the choice to the BCS 852/853 with dry clutch, and the BCS 749 with the "Powersafe" hydraulic clutch. The Diesel engine was considered for a few seconds, and then we decided on the Honda gasoline engine engine due to lower initial cost, much lower replacement cost if needed, and less weight on the back when the tractor is used for mowing. The tractor decision for use came down to the BCS 853 with the dry clutch, or the BCS 749 with the Powersafe wet clutch, both the 13 HP Honda gasoline engine . We decided to go with the 749 with the Powersafe though I expect either would have been fine for us.
After a summer's use we are happy with Powersafe clutch. The clutch engages smoothly by just releasing the clutch lever. It's nice to be able to let go of the left handlebar and have the engine continue to run. The brake which is applied when the clutch is disengaged and stops the tractor has been useful, particularly when the tractor is pointed up or down a slope. Since we don't ride behind the tractor the inability to coast in not a issue. The sequence of squeezing the clutch lever, pushing down on the red safety lever, then releasing the clutch handle to engage the clutch after the red safety lever has been released to a little while to internalize, but is now done without thinking about it. The only minor drawback I've found is the difficulty in "feathering" the clutch to facilitate shifting into a gear or engaging the PTO when the teeth don't line up initially, but I've gotten use to it.
The larger, optional 6.5x12 wheels and tires rather than the standard 5x10 have proven to be the absolutely right choice for mowing on our property given the many ruts, lumps and bumps and rocks. The increased ground clearance under the tractor transmission keeps it from grounding out, and the larger diameter tires provide a smoother "ride" and less resistance over bumps and rocks. One area has some deep ruts caused by a 4 wheel tractor previously mowing when the area was very wet, which The 6.5x12 tires are barely adequate to traverse over. We had initially thought we might need dual tires due to the wet areas, but so far the single tires have not caused any noticeable ruts.
Two pairs of wheel extensions were installed for a 10" increase in track. The distance across the outside of the 6.5x12 tires is approximately 31", which fits inside the cut area of both mowers. The stability on side slopes is significantly increased, and the wider track also has helps keep the tractor upright when a tire drops over the edge of an embankments hidden by tall grass and dense vegetation. The two wheel extensions on each side increase the space between the inside of the tires and the transmission. Several times when I first mowed tall grass (up to six feet) with the sickle bar mower, grass wrapped tighly around the wheel extensions. I learned to keep an eye on the wheel extensions, and as soon as grass starts to wrap to take action to stop it from wrapping. Frequently some I can simply step forward on the grass and the grass pulls free. Occasionally I need to back up a couple of feet and the grass unwraps . Since I started watching for the grass to wrap I've only needed stop and unwrap it by hand a couple of times. I consider the wheel extensions essential for mowing on our hills and embankments.
   / BSC 749 and mowers experience #3
Useful info. Thank you! I found the ruts impossible with my BCS 740 equivalent. Completely lose control on a slope. I thought I might need tracks...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
