Brushgrubbers by BAC Industries
   / Brushgrubbers by BAC Industries #1
Arky217
Hartford, AR
Kubota L4200
Hi,
Has anyone used one of the brushgrubbers by BAC industries.
BrushGrubber | Home
Besides the original model, they make 3 heavier models:
Heavy duty, 3/4" constr., jaws open from 1/2" to 4", 14 lbs.
Extreme, 1" constr., jaws from 2" to 5", 24 lbs.
Extreme plus, 1-1/2" constr., jaws from 2.5" to 6", 36 lbs.
I was thinking of trying out the Heavy Duty model.
It doesn't appear that the extreme models would clamp on the smaller brush whereas a chain should work just as well on the larger brush.
   / Brushgrubbers by BAC Industries #2
Looks like a toy that would fall off at the first chance or just strip the bark off . A saw blade on a brush cutter would be far better , cut off at ground level and a follow up with Glyphosate and they would be gone .
   / Brushgrubbers by BAC Industries #3
I have the HD model and it works well. It is faster if you have a second had to hok and release for grubbing 3 4 inch stuff roots and all. I have since put a grapple on the tractor and use it less often.
2012 VOLVO VNL TANDEM AXLE SLEEPER (A53426)
2012 VOLVO VNL...
2008 Ford F-450 SD 4WD Pickup Truck (A53117)
2008 Ford F-450 SD...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
