Brush Hogs and swaybars
   / Brush Hogs and swaybars #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
Hey guys,
I bought a 5' hog for my Iseki and was told by the dealer that I didn't need to attach swaybars - just hang it on the 3-pt. This lets it swing L-R about 2' and it doesn't feel right.
What are your opinions on his advice? Apart from "feeling crappy" is there any risk (to me or the tractor) if I don't have them?
Cheers!
   / Brush Hogs and swaybars #2
Personally, I would use the sway (stabilizer) bars. They make a big difference in keeping the cutter tracking correctly and just give me a better feeling about operating the machinery.
   / Brush Hogs and swaybars #3
The less anything move around the less wear and tear you get. I also think it would make the tractor a lot more stable if you are on the side of a hill.
Bill
   / Brush Hogs and swaybars #5
Absolutely!! Restricting movement slows wear and tear and promotes stability.
Right-on. As soon as I get outta work, I'm going to go and buy stuff to fix this! (Did you notice how heavily I relied upon that technical term "Stuff"!).
Happy NewYear to all you guys!
Remember - Keep the shiny side up and the rubber side down in 2009...
   / Brush Hogs and swaybars #7
I need the sway bars tightened on my 4010, because the brush hog would otherwise swing the lift arms to where they'd rub one of the rear tires. I also wouldn't want that 450# of so wandering around back there. On a hillside, if it suddenly swayed to one side, that could be just enough to send the tractor toppling. Sitting on a tractor with a brush hog going dangerous side up is not my idea of fun. With you in your seat belt, you'd hopefully stay on the correct side, but what it the seat belt let go or wasn't tight enough?
Ralph
   / Brush Hogs and swaybars #8
I've used a cutter w/o them (old 8N), and with (new Branson).
Get some and use them.
I'll add that you want to be careful how tight you make them tho...I don't think a little "give" is that detrimental, especially if you swing into something while turning.
Good luck and good cutting!
Lunk
Hmmm... Food for thought. I'll get them, put them on, tighten them up (but not TOO tight) and see how I go!
Thanks folks!
   / Brush Hogs and swaybars #10
Hey guys,
Cheers!
I think your dealer needs to find another line of work. Reducing sway is essential in operating implements on the 3pt hitch.
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
1995 PETERBILT 379 SLEEPER (A53843)
1995 PETERBILT 379...
2021 JOHN DEERE 524P LOADER (A52705)
2021 JOHN DEERE...
