Brush hog safety chains
   / Brush hog safety chains #1
Mtsoxfan
Platinum Member
Newark Vermont
New Holland TC29D
Snow finally gone, at least where the grass is and I'm getting the brush hog ready for the field. The safety chains that prevent debris from coming out unchecked is missing quite a few links. I figured before I replace I'll ask my question...
Has anyone replaced the chain guard with anything else? If so, how'd it work out? Any pics?
   / Brush hog safety chains #2
I've seen a horizontal strip of a rubber belting type material used. Is it the front, tractor side of the mower or the opposite back side?
   / Brush hog safety chains #3
My 15ft Bush Hog batwing had the option of chains or a rubber strip (cheaper). I chose the rubber strips. They lasted 15 years but now need replacing. I am not sure which way I'm going.
Ken
   / Brush hog safety chains #4
Belting seems to keep the grass under the mower better than chains but may also bend the grass down more in front so doesn’t cut as well.
Never ran side by side test to see if one option created less dust than the other
The rear is missing the most. If I can get a better idea over chains, I'd do both.
One of my thoughts was similar to yours, truck mudflap. Haven't thought about the design yet.
Belting does sound safer as well. I'd imagine if a link gets airborne, not safe...
   / Brush hog safety chains #7
Ken
Once I was lucky enough to obtain a length of discarded conveyor belt from a coal mine. It's ½" thick and 4' wide; my section was 20' long.
I never gave a thought to use it on the rotary mower, I used it for mats in my horse trailer.
What I'd be cutting is a hayfield and saplings. I've cut some of the unkept hayfield last year, tons of seed/chaffe plugging up radiator screen. Hoping to cut more often so it doesn't get to that point, dry and over grown. Time will tell how often, but the section I cut last year was about 6 times, vs my grass every week.
   / Brush hog safety chains #9
Depending on width old round baler belts are tough and usually pretty inexpensive since they are headed for trash bin or the I will use that someday pile…
Any pictures of mounting?
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2006 Ford F-150 Ext. Cab Pickup Truck (A42744)
2006 Ford F-150...
2024 Ford Maverick Crew Cab Pickup Truck (A42744)
2024 Ford Maverick...
2005 Great Dane Trailer, VIN # 1GRAA96265S700587 (A44391)
2005 Great Dane...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2012 CHEVROLET 3500HD 4X4 TRUCK (A43004)
2012 CHEVROLET...
