Mowing brush hog mower for a 26xl
   / brush hog mower for a 26xl #1
bobholland
Willamette Valley, Oregon
Mahindra 26xlHST, JD 870
I've seen some posts that folks are using a 60" brush hog behind a 26xl. I spoke to a dealer who said a 48" was the recommended size. I am looking at the Mahindra rotary cutter either in 48 or 60 inch and would prefer the bigger coverage. I am mowing grass with some small willow patches up in the mountains of Oregon. Wondering what folks experience is with a rotary cutter and the 26xl?
   / brush hog mower for a 26xl #2
you can easily swing a 5' hog behind that 26. I do regularly, also swung the 5' on the Max 24 with no issues other then the weight on the back. I traded in the max 24 and got a 2538.
Dont worry you will be fine with a 5' hog, dont go 48" not wide enough to cover the tires. GOOD LUCK
Matty
   / brush hog mower for a 26xl #3
Forgot to add.....
I have a 5' mahindra rotary cutter it is made by kodiak, it tackles everything...... 2" saplngs with ease...... also have hit a few 3" to 3 1/2" saplings....... chomp chomp chomp
Just make sure you get a slipper clutch.... not a shear pin......
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
LINCOLN WELDER (A55745)
LINCOLN WELDER...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A55745)
2018 RAM 2500...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
