Brush hog- How large?
   / Brush hog- How large? #1
Phred
Veteran Member
Arkansas
TN70D, 4wd, 16x16 trans
I know that this topic is not new but I would like to get some specific info on my problem.
I have about 90 acres that I am currently building a home on. Ultimately I will be buying a tractor in the 50-70 pto hp range. However, I would like to wait till next year since these units are hardly free.
The problem I have is that I can rent a number of tractors but the rental places do not want to rent a cutter due to liability.
So I am thinking about buying a cutter to use with rentals until next year and then use it with my tractor.
The problem is how big. A bat wing is out since most rentals are in the 42 pto HP range.
If I buy a cheap 6’ at tractor supply will it work with the rentals and still be useful for a TN75? Will this be a dissappointment next year?
Also what about pto shafts? Will one unit be universally compatible with any tractor? I have heard about issues with the length.
Thanks for your help.
Fred
My options are:
Woods 72 Brushbull asking ~$1600
Brushhog 287 Asking ~$1600-1700
Alamo A72B asking ~$2000
International 6' $895
King Kutter 6' ~$800 @ tractor supply
A used modern 5' for $500. Will not cut out the tracks of a TN series tractor. No rust on this unit but its "as is" at this price.
Anybody own one of these and have a good or bad expereince?
Thanks,
Fred
   / Brush hog- How large? #3
I picked up my new Bushhog 286 (6' $1500.00) today and cut around 4 acres of waist high fescue. I'm still undecided on the quality of cut. I had it set at it's highest level (around 12 inches I guess) to avoid hitting rocks. It seemed to lay the grass down in the center and not cut it as short as the grass directly behind the wheels.
Jeff
   / Brush hog- How large? #4
Fred,
Here's my 6' KingKutter working.
Bush Hog, Woods, and Alamo {Terrain King} all make great products. The Woods BrushBull is too new to determine gearbox reliability, but it sure looks like a winner in the steel department and design. The Bush Hog is a proven time tested design. Alamo is more a consumer unit versus the Terrain King HD line. You can almost flip a coin between Woods and Bush Hog... they both should last for even your children to enjoy... /w3tcompact/icons/smile.gif
"You are what you eat, drink, think, say and do..."
   / Brush hog- How large? #5
Phred,
Two additional things to think about in making a determination on this type of equipment. Weight and Size. Compare what they all weigh and if possible measure the size of things like the gear box, the stump jumper (diameter and thickness), etc.
I didn't look at the 6' or 7' models, but for the 5' models, the Woods Brush Bull 600 medium duty cutter was the best in my opinion. I have used it to cut everything that it can push over. A couple of dozen rocks and stumps were also "disovered" while going backwards, and the only indication is a couple of very small dents in the deck. I think the size of the BB600 stump jumper helps out. (oh yeah, be sure to wear hearing protection....)
Have fun!
John Bud
   / Brush hog- How large? #6
My personal opinion is htat if you're going to have that much ground to do I would get a minimum of a 7' and would recommend you get an 8' one. With that much ground it's already going to take you a long time with one of those.
Thanks guys,
Cowboydoc; Your right what I really need is a 15' batwing or 10' pull type. However, not in the budget. Besides I have some tight places that will be difficult to cut with a very large cutter. Some day I will have to save up for one of these.
Also in the long term I will probably be haying most of this land and will only need to cut the road sides, and fence lines.
Thanks for all the advice.
For me in the end it was a draw between the bush hog and the woods. In the end I bought a bush hog 286, because they were out of the 6' woods.
I have a TN65 for a week to try it out on. /w3tcompact/icons/smile.gif
Fred
   / Brush hog- How large? #8
Phred,
I got an old 8' Woods that someone had traded in awhile back at the JD dealer for $625. The steel on it is thicker than any other new brand I've seen. It works great and only thing is all the paint is worn off of it.
   / Brush hog- How large? #9
Fred,
I bought a Bush Hog 286 about 5 years ago and let me tell you this is one tough cutter. Now I am looking at a Bush Hog 3210 (10.5’) but there will always be a need for a smaller cutter in those tight places.
Bulldogger
cowboydoc,
I don't doubt that at all, the woods seems very strong. They just did not have any 6' woods in stock and the brush hog also seems very well made. I suspect that if well maintaned they will both last forever.
Is that a pull type or a three point? How does your tractor handle it?
Fred
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A43004)
2019 INTERNATIONAL...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A45046)
2011 MAGNUM...
Fleco 48" 26.5T Long Reach Excavator Smooth Bucket (A42203)
Fleco 48" 26.5T...
2016 Ford Fusion S Sedan (A44572)
2016 Ford Fusion S...
2013 Ford F-550 Truck, VIN # 1FDUF5GY8DEA24690 (A44391)
2013 Ford F-550...
2006 CHEVROLET EXPRESS SERVICE VAN (A43003)
2006 CHEVROLET...
