"Brush Hog" deck?
   / "Brush Hog" deck? #1
MSLewis
Craftsman GT 5000 917.276090
There's a guy on craigslist selling a GT 6000 for $125, running, good tires, but no deck (sears gt 6000 parts tractor). I'd be half tempted to grab it up, or something like it, if I could find a small "woods" deck to put under it to use off the lawn - something that'd cut through small saplings, briars & vines, etc. Does anyone make such a thing? Can heavy-duty blades be had for a deck?
   / "Brush Hog" deck? #2
I'd be more worried about spindles and such. It's just a lawn mower, so I doubt anyone makes a haevy duty deck for it. That's just my guess. For $125, maybe it would make a good snow pusher?
   / "Brush Hog" deck?
Not enough snow here in Georgia to warrant anything like that. I have seen heavy duty spindles, though. Perhaps I could build my own "off turf" deck with those.
   / "Brush Hog" deck? #4
There is a guy here in Houston Texas area that builds "bush hogs" from ground up (except gearboxes) that could probably build you one for the lawnmower. You may have trouble pulling a bush hog that would cut what you are asking. We say you need 5 tractor PTO HP per foot on a bush hog. I have no idea what a 25 HP lawn mower motor would put out in actual rotary HP. Give this guy a shout Clem Clemson [okyet1@hotmail.com] if you want a deck build, he may be able to help you
   / "Brush Hog" deck?
Thanks for that lead. At the very least, he may be able to authoritatively advise. I appreciate the input.
Ideally, I'd want a "belly hog" to swap out with the mower deck, not a pull behind. Narrow deck, single heavy blade, perhaps even a swiveling blade.
   / "Brush Hog" deck? #6
Pull behinds with their own motor are common, relacement under decks aren't. Swisher and bush hog to name a couple.
David from jax
   / "Brush Hog" deck?
Maybe what I'm looking for is just a spare "beater" deck. I'm not talking about cutting down trees - just the random sapling (smaller than half inch), brambles, twigs, etc.
2017 Ram 5500 Crew Cab Reading Service Truck (A52377)
2017 Ram 5500 Crew...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2015 FREIGHTLINER...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
