Brush cutter
   / Brush cutter #1
swatter
Bronze Member
Alabama
Kubota BX25D
I was out Christmas shopping with the family and at the local flea market I noticed new and used tractor equipment. They had new 4 ft brush cutters for 450 and 5 ft for 550. These were no name so I would assume cheap Chinese made equipment. Since I own a bx25d what is everyone's opinion on buying one for cutting brush like once or twice a year. Also they had some new 3 point scrapers for 125.
   / Brush cutter #2
No name = no reputation (speaking for myself) to form a reasonable opinion.
You pay your money and you take your chances.
If the gearbox blows up, who you gonna call?
I have had mixed results in this kind of transaction.
Some have been great - some ... not so good.
You are really casting dice, so spend only what you are willing to write off as a complete loss if it goes badly.
If it means either having a brush cutter or not, then you have to make that call.
   / Brush cutter #3
Go on Craigslist or tractorhouse and find a used brand name cutter for the same money or less. It'll outlast your tractor.
   / Brush cutter #4
Should be fine for occassional use with your tractor.
Buy the 4', not the 5'.
Lubricate all Zerks each use and pay attention to the gearbox seals. Do not operate the mower without adequate lubrication.
SDT
   / Brush cutter #5
SDT
Also don't forget to put gear oil in the bush hog gear box. They don't normally come with oil in them.
I would go for it if the price is 50% of another branded version of likely the same piece of equipment.
It could be chancy on a no name brand but also if Chinese made, it could be the same manufacturer as many other locally sold brands. Lots of Chinese made equipment including gear boxes on the "USA made" brands. Gear box is about the only wearable item on a bush hog that is expensive to replace and most of them now days are Chinese.
   / Brush cutter #6
I see you are from Alabama. What part? LMC makes some good stuff and it's cheap and you can easily get parts.
   / Brush cutter
I live in Cullman next to you in Arab. Thanks I will check into LMC. Also thanks for the tip on checking the gear oil.
   / Brush cutter #8
LMC is over in Boaz. I have one of their HD 6' models if you are over this way you are welcome to take a look at it.
Allen
40ft Shipping Container (A52377)
40ft Shipping...
LIKE NEW John Deere 10 Lug Sprayer Wheels and Tires (A53473)
LIKE NEW John...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
1 pallet of Truck Air bags (A53117)
1 pallet of Truck...
1999 Ford F-550 12FT. Flatbed Truck (A51691)
1999 Ford F-550...
Bush Hog R0-720 Roll Over Box Blade (A51691)
Bush Hog R0-720...
