Brush Cutter Snap Ring Warning
   / Brush Cutter Snap Ring Warning #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
I sheared the bolt on my brush cutter the other day and the shaft came off the gearbox and started framming around. Just thought I would pass a warning to all to make sure the snap ring is on your gearbox yokes.
I have had this mower for years and never sheared a bolt. Had no reason to remove the shaft. Shaft is 1-3/8" and nobody had a snap ring to fit locally. I had to order a 25 pack from McMaster Carr which cost $7 + $7 shipping. I'll have $14 invested in a 50 cent part but can't afford to not have it on there.
I'm pretty sure I got lucky and the shaft caused no damage. I hit the PTO button quick when I heard the noise. PTO shaft on tractor is running true and no leaks so hopefully it's just put the snap ring on and replace the shear bolt.
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
1271 (A50490)
1271 (A50490)
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
