Brush cutter blades
   / Brush cutter blades #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
The kind I'm referring to is the saw type.
Does size matter? I see them listed as 8", 9" and 10". I know they have to be rated to at least 10,000 rpm, but if they clear the guard does size matter? The Stihl owners manual does not say anything about that.
   / Brush cutter blades #2
You would get higher tip speed with larger diameter so faster cut presuming you have the power to drive them.
OK, I figure larger dia. will take a little longer to wind up also. So basically I'm good to go with any of the above sizes as long as I don't over stress the clutch and or motor.
   / Brush cutter blades #4
I didn’t like the larger sizes. Take too long to spin up and too long to slow down ( more dangerous). I like 7 1/4” skilsaw blades, they’re cheap too. You have to cut a “diamond” on your spindle for the knockout.
   / Brush cutter blades #5
I prefer the bigger ones. They cut a wider path in thick small diameter brush and have more momentum to cut bigger stuff.
   / Brush cutter blades #6
Bigger is better for the ground, for sure. Smaller/ lighter is better for trimming with care and especially if you’re cutting overhead.
   / Brush cutter blades #7
I only use this attachment for mass destruction where a bushhog won't fit. I've got a pole saw attachment for the 'precise' work.
Interesting, I've only seen those blades rated for 7,000 rpm max and all saw type brush cutter blades 10,000 when it's even listed. I've been curious as to why the different ratings and what would happen if you exceeded them. The 9,000 - 10,000 rating is applied to non saw type blades also. Could it be a balance issue? I've never seen an explanation.
   / Brush cutter blades #9
No idea why a solid steel unit has a speed rating.
My perspective comes from using Skilsaw blades for "trail cutting" for over 20 years. Smaller blade provides the option of "selective" cutting, the bigger blade cuts everything in the vicinity. Remember it's on an extension and when it bounces off one branch it cuts several around it while spinning down. It's much more dangerous, and pretty bad 'overhead'. 7 1/4 is dangerous enough, thank you!:shocked: I don't use a "guard" its just open saw teeth. I use the "small kerf" or narrow cut type blades for minimum rotational weight. As I wrote - to spin up faster, and conversely to spin down faster. Or you can rub it on a log to slow it if you have to.
Small blade is safer to cut bushes under a fence, and around fenceposts or wire.
In the last few years though I've been doing "fuels reduction" where I can cut saplings all day long (at ground-level). Reading this thread reminds me that I ought to try the bigger blades again as it's walking thru a generally open forest which is pretty safe for the big heavy blade. And lots of 3+ inch saplings. There would be a lot of saplings on the ground (to drag away). But very efficient, no stumps, with no bending over, and no filing a chain.
4570Man - I have a polesaw - and it sits. Polesaw is much too slow & strenuous. It's OK if theres only 5 or 10 cuts, and then only if the weed/skilsaw can't reach it. I thought the polesaw would be such a great tool, and I guess it is,,,,, but mine's in "as-new condition" after several years. I don't doubt that a polesaw works well, I just doubt that someone who has both - will ever choose the polesaw for jobs the weed/skil can do.
I have a brush hog and the areas mowed often re-grow at the same rate. At my place it was forcing a "cycle" where I HAVE to hog it again but the tractor can't go under low trees or bushes, or on steep areas. I don't like that look. Wherever you cut to the ground, the bushes grow back like lawn, same age, same height, and there's certain weeds that take advantage of the sunlight on the dirt. If you cut selectively, the existing bushes stand their ground and compete with the other weeds. It's a balance you can "assist with" but depends if you care how it looks. I found that there's less work when you don't fight it so much, but it does require more scheming. It took a few years to figure this out, and I think what caused me to think that way was the time it takes to hook up the brush hog (and unhook). I'd be done, with a better job, with the weed/skil doing it incrementally whenever I feel like going for a walk. I have a certain look that I like near my road. I call it "forced natural".
In any case, the weed-wacker with the skilsaw blade has been an efficient tool that gets a LOT of use.
And to each his own.
   / Brush cutter blades #10
Use the size blade designed for your cutter, and use the shield that is designed for that blade. If your cutter is not designed for use with a blade, then don't use one on it. Don't try to slap a blade on your weed whacker and call it good: the drive shaft and gears likely can't take it. It's a great way to ruin an otherwise perfectly good weed whacker.
2008 John Deere 608C combine head (A50657)
2008 John Deere...
CATERPILLAR 303E EXCAVATOR (A51242)
CATERPILLAR 303E...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2019 FORD F-350 SERVICE TRUCK(INOPERABLE) (A50854)
2019 FORD F-350...
