Broken TU1700
   / Broken TU1700 #1
gmatt
I am the proud owner of a broken TU1700. Tried to push over one too many trees and broke something in the front wheel drive, mosy likely a spider gear in the differential. Tractor drives fine and noiselessly in 2WD.
Questions: (1) Before I tear this thing apart to fix it, where can I get an English repair manual. (2) Is the 1700 similar enough to another make to use their repair manual for it (e.g., Ford, Massey) (3) What fluid type goes in the trans/hydro fill??. I'm guessing this model has a joint reservoir that will pee all over the ground when I open the front end to see what I broke...
   / Broken TU1700 #3
How did things turnout? I've got the same problem.
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
FRONTIER  ROUND HAY BALE SPREADER (A52472)
FRONTIER ROUND...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
