Broken steering LH knuckle Kioti 1914
   / Broken steering LH knuckle Kioti 1914 #1
larydare
Garden Valley CA
Kioti LB 1914
I have a Kioti 1914 Diesel 4X4 with a broken LH steering Knuckle Arm. Receiving a new one tomorrow and they are very expensive; so I want to make sure I get the proper adjustment when replacing as to NOT have so much force on the steering knuckle arm as to cause it to break again. I ran over my chain saw but the knuckle arm did not snap then but a little later when turning slight to the left. Steering rod and all else looks fine. It is a bummer not having my tractor working.....Chainsaw works, had to replace the handle bar was all bent, thanks and enjoy your day....larydare1@aol.com
   / Broken steering LH knuckle Kioti 1914 #2
Welcome to the list. I don't have an LB or any LB manuals; so I won't add my ignorance to muddy the waters. Hopefully another LB owner or someone who has changed a knuckle arm will jump in.
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A50323)
2006 Mack CT713...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
