Broken spring
   / Broken spring #1
Toby873
Bronze Member
myakka city, Florida
Branson 4720i
I found a broken spring under my clutch pedal. I can not see immediately where it went. It is a bright metal spring maybe 2 inchs long about 3/4 inch diameter. Where does it go and what does it do? Clutch seems to work fine without it but dont want to ruin something if I can help it.
Toby
   / Broken spring #2
Toby- Are you sure it is not a strap that holds the clutch petal down for long storage periods? Thats what it sounds like, Take a peak in your manuel
   / Broken spring #3
toby-the spring is the clutch return spring. mine broke this past summer, went to dealer for new one. take off dash to see better, put new one on,good to go. 15min. job, about 6 dollar cost.
   / Broken spring #4
Go to TSC if you can. Mine was twice that much at a dealer.
   / Broken spring #5
I had the exact same thing happen about 6 weeks ago. You will need to remove the dash to access the location to replace the spring. My dealer is not close so I took the spring ( in 2 pieces) and went to my local farmers COOP and found one similar. I bought 2 since they were $1.50 each so if / when it happens again I will have an immediate replacement. FYI mine broke with about 110 hours on the tractor.
   / Broken spring
Thank you all, ray my 4720i has 115 hours, TSC this weekend, love having a valid reason to go there
2007 Boston Whaler w/ Dual 200HP Mercury OptiMax (A51694)
2007 Boston Whaler...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2003 Ford E-350 Van (A51692)
2003 Ford E-350...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
