Broken ROPS tightening screws
   / Broken ROPS tightening screws #1
getut
Platinum Member
NC
Kioti CK20HST
Well, It finally happened. I got so tired of tightening up the ROPS tightening screws every 5 minutes during use that I started just leaving them and letting the ROPS rattle.
Well the effect this had over time was it bent the ends of the bolts down at a small angle and broke one of them off. I broke the plastic part off the other end trying to back them out. Now I have 2 bolts with the plastic handle broke off and no way to get them out. I think they are far too tight for easy outs to bring them out of the hole, especially considering a big pipe wrench couldnt get a good enough grip to get them out.
Currently I just have a wooden wedge driven down in each side to stop the rattling... and it is working better than the bolts ever did.
   / Broken ROPS tightening screws #2
Pull the pivot pin out and remove the ROPS, then you should be able to screw them out the back side. If they're not too tight a drill might screw them out, other wise use an easy out from the back side. I took mine out and put them in the tool box, it doesn't rattle, or I don't notice.
   / Broken ROPS tightening screws #3
</font><font color="blue" class="small">( Currently I just have a wooden wedge driven down in each side to stop the rattling... and it is working better than the bolts ever did. )</font>
that's too funny...I had the same thing happen to mine over a year ago, I had to hacksaw what was left of the old bolts out and I also use a wood wedge to keep the ROPS from rattling!
sounds like something that could use some improving...
   / Broken ROPS tightening screws #4
Yep, I think this is a common occurrence on the CK20. I haven't even bothered to put a wedge in, but plan to ONE day when I get irritated by the rocking!
John
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
