Broken PTO button
/ Broken PTO button #1
Bill_B
Bronze Member
Mahindra 2615
My PTO button broke the other day. Is this a common problem? Seems like a poor design. You shut off the PTO by slapping the PTO button but if you do that when it is cold the button breaks. Cheap plastic junk.
Is there a more rugged option?
/ Broken PTO button #2
On my dk45 its just a standard rocker switch
/ Broken PTO button #3
Yep mine broke on my NS4710.
/ Broken PTO button
I think i am going to convert to this type. Cheaper and probably won't break so easy.
/ Broken PTO button
I ordered this yesterday. Its way cheaper, not cheap plastic, and the same diameter.
I'll share pictures when I install it.
/ Broken PTO button #6
Search Starlight Tractor Parts on eBay. He makes replacement parts
/ Broken PTO button #7
I've been using mine with the broken switch for 2 years now. Major PIA turning pto on and off by having to pinch that broken off nub. Haven't had time to replace it yet. I did get a new one from the dealer.
Not a fan of these type of switches. Wish it was a simple rocking switch. No idea why it has to be this type. Absolutely no benefit.
/ Broken PTO button
This is what I recieved. It is smaller than I thought it would be (that's what she said ).
Banana not included.
I am gonna give it a shot. They did have a larger version but I didn't want to drill the hole out larger incase I wanted to go back to the original switch for some reason.
/ Broken PTO button #10
Is there a more rugged option?View attachment 4509459View attachment 4509460View attachment 4509461
I just fixed mine. The switch worked but the ring would not hold the switch in place. I took the switch into the hardware store and matched it up with a 7/8" snap ring. I also got a bushing, I think a 1" bushing for added support. I cost about $2 for the fix. Remove the 3 screws securing the gray plastic tray, hold the pto switch in place. Put the bushing or flat washer in place then place the snap ring on it with snap ring pliers. It works great.
/ Broken PTO button
I took some measurements incase I go with a different switch eventually.
I ohmed out both switches to figure out the wiring. I installed the new switch into the panel. Haven't installed onto the tractor yet.
I kind of wish I had ordered the next size up 22mm. I may order that one and swap it out eventually.
/ Broken PTO button #12
Dont understand why they didnt use a rocker switch to begin with. My switch is 14 years old…no issues.
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
