Broken Mower Blade Bolt Ideas
   / Broken Mower Blade Bolt Ideas #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, so I had my tractor at my friends house yesterday to extract the two broken bolts.
He had two systems in mind. The 1st was buying a custom type bolt that had a rounded head and was screwed in from the top. It would mean drilling a few holes in the mower deck, and I am not completely sold we can find bolts to work but we are looking.
The second is this crazy idea. What about welding a piece of metal as a bolt guard onto your mower blade. Anyone try this and if so results? My friend feels it would be a protection to the bolt head which is probably taking the impact.
   / Broken Mower Blade Bolt Ideas #2
Welding on the blade might change the hardness of the blade making it more susceptible to cracking at the weld points. If you do decide to go this route make sure you balance the blade after welding on it.
   / Broken Mower Blade Bolt Ideas #3
I would try to find a blade that has an offset in it, so that it doesn't hit the bolt when it swings around. Possibly you could put a spacer on the stump jumper that lowers the blade as well. This should work.
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
FRONTIER FAV20 LOT IDENTIFIER 65 (A53084)
FRONTIER FAV20 LOT...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
