Broken Lift Arm - Fix or Replace?
/ Broken Lift Arm - Fix or Replace? #41
What is 4 lbs of steel compared to the cost of replacing that roll over assembly plus labor, and others also thinking when will mine bend or crack. The answer should be with PT, to re-engineer that roll-over assembly and not rely on the working masses to come up with a solution. A typical statement from PT would be, have you been working it to hard, or it shouldn't break like that. We will be happy to send out a replacement at full retail price, and you do all the labor. What a deal . /forums/images/graemlins/smirk.gif
/ Broken Lift Arm - Fix or Replace? #42
Has anyone had this problem with the red PT's? I have beat on my 1430 pretty good and no problems yet. Of course, now that I've said that, I'll probably have grease squirting out all over.
/ Broken Lift Arm - Fix or Replace? #43
I have a red 1445, and have replaced mine.
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2010 International 4400 S/A Day Cab Truck Tractor (A59230)
2010 International...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
17307 (A55853)
17307 (A55853)
207283 (A52708)
207283 (A52708)
