broken kubota snowblower
/ broken kubota snowblower #1
Roadog128
Kubota B3200
Took the reduction box cover off B2782A to check chain tension. Noticed the two bolts holding hub looked bent going into sprocket. When I tried removing them, they broke in two. Managed to remove pieces. Holes in hub look egg-shaped and do not line up with sprocket. How do I line them back up and should I use grade 8 bolts instead of the 5's that broke? Thanks, Randy:confused2:
/ broken kubota snowblower #2
You need to use a tapered drift pin for the line-up. As far as the holes being egg shaped that's because the bolts had got loose and you had movement.Use the same grade that is requires and use lock nuts and or Blue Loc-tight.I had a blower like that and before use check all bolts for tightness. That area shoud be easy as that's where you can lube chain.
DevilDog
BARRY HILL 20 GALLON ALLY WAY SPRAYER, 3PT (A63291)
BARRY HILL 20...
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
Kubota M125X (A60462)
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
