Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,057
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We've got a 10' Rhino rotary cutter. Bought it used. When bought, seems though the seller said it was "field ready" he lied
. Just to get it hooked to the tractor we've had to replace the double yoke on the pto end of shaft (about $600), the two yokes and universal at the opposite end (about $400 I think) blades ($150).
During that, I noticed the jackshaft (if that's the right name...?) the 1/2 shafts that go from the main gearbox to the side gearboxes. It's about 13" in length and connects with a rubber shock absorber type thing.
Anyway, with the prior damage of mower, the 1/2 shaft on the same side as bent blade had a visible though small twist in it. Clearly someone hit something and the force bent the tube a bit.
Was cutting field yesterday and the mower was doing GREAT until I found a stump
Whacked the stump and now only 1/2 cutting width.
The 1/2 shaft completed its torque and simply spun into two pieces, much like taking a tootsie roll and twisting it while pulling apart.
Now, for the record, I've ordered a NEW 1/2 shaft today ($400) as well as a new set of those rubber connectors, just to have them.
What I'm wondering is, might I be able to get the old shaft repaired by a machine shop?
The shaft has two end pieces, both being grooved to slide onto the splined shafts of each gearbox (center and then side). To the end pieces, they welded a tube. Much like taking the cardboard tube from the center of a roll of paper towels and welding the splined receivers onto each end.
What I'm wondering is, might it be possible for a machine shop to remove the "cardboard tube" section and replace it with something else?
This is really just out of intellectual inquiry as I've already ordered a new one to replace it BUT... if it MIGHT be possible to fix something like that then we might have it fixed and keep it on hand as a fill in should this ever happen again.
