broken hydraulic hose bh75.. need help
/ broken hydraulic hose bh75.. need help #1
dougj7
Bronze Member
Pine Bush, NY
Kubota B2630
Hi, I just broke a hydraulic hose inside the boom on my bh75 backhoe. The hose runs inside the boom and there is no way to reach the fitting to replace the hose. Do I have to remove the boom cylinder? Thanks, Doug
/ broken hydraulic hose bh75.. need help #2
If the cylinder is in the way and there is no other way to get to it, then yes.
Pine bush huh? Don't go to PBE, unless you are rich.
ok.. next question. Any hints for removing the cylinder.
Yes, PBE is too expensive for me. I didn't even purchase my tractor there.
/ broken hydraulic hose bh75.. need help #4
To remove the boom cylinder, you will have to lower the boom as low as
you can, remove both pins, and extract the cyl from inside. If you can
not lower the boom enough, you may have to lower it into a hole or
remove the dipper too. Remove the lower cyl hose before trying to pull
the cyl out. Not an easy job.
/ broken hydraulic hose bh75.. need help #5
You can that hose custom made. Not sure how they sell American made Fittings at these prices, just ordered 2 hose assemblies for our stump grinder - The Hose Company
4 posts related to the same company in 4 minutes.......
You want to pimp your product become an advertiser and support the forum. You will get more positive response then hijacking every post with your link.
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
213324 (A64279)
213324 (A64279)
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
