richardbro
I recently broke a grease fitting in a pin on my BX24. The grease fitting snapped off leaving part of the grease niplpe thread screwed into the pin.
Took the pin to the dealer and the mechanic quickly extracted the broken piece and replaced it with a new grease fitting. Unfortunately I didn't stick around to see how the broken piece was removed.
I just broke another one
Anyone have an idea how to extract the broken threaded piece from the pin? I'd rather not go back to the dealer so soon
Another question - being a newbie at this I apparently was removing my grease gun the wrong way from the grease fitting when greasing. My method was to angle the gun to the side until the grease gun tip would pop off the the grease nipple. The repair person at the dealer told me to instead pull straight out but this seems pretty difficult at times. There's a little button at the front end of my grease gun tube that I press while pulling the gun - this seems to be letting in air (I guess) and seems to let the grease gun go a bit easier. Is this correct? Is there an approved method for this procedure? Have I been sniffing too much grease?
I expect other grease fittings to break in the near future - I may have weaken them in that past little while...
