Broken flex drive shaft
   / Broken flex drive shaft #1
BubbaJr
Platinum Member
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
I have a Troy Built 4 cycle power unit with a weed trimmer, brush cutter, and a pole saw. It runs great, but while using the pole saw, I managed to break the flexible drive shaft in the pole saw power head shaft. I contacted Troy Built, and they only listed the shaft assy. including the actual flex shaft. That part has since been discontinued. Then I tried to match the part up with MTD since they make the Troy Built now. I found what I thought was the same flex shaft, but it is 4" too long.
I tried all over my county to find someone that could re-stake the square end on it after I shorten it, but no one had the equipment to do it. So I found some metal, got out the file and made my own dies to hammer the square stake on the end. After getting it all set up and whacking it with the biggest hammer I have, I discovered that I only managed to dent the metal dies, and didn't touch the shaft. I found out that it is VERY strong steel.
Do any of you know where I can get a 1/4" flex drive shaft from stock or made to order? It looks similar to this one, but is 20 1/2" long.
http://www.ereplacementparts.com/images/part_753-05182.gif?osCsid=mb6oqht9qru3jip9dlcifao2j6
Terex TSR-50 Skidsteer (A48837)
Terex TSR-50...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A50397)
2016 Ford F550 4x4...
Vacuworx MC3B Vacuum lifter (A50860)
Vacuworx MC3B...
2024 KUBOTA KX080-5 EXCAVATOR (A50458)
2024 KUBOTA...
2019 CATERPILLAR 279D SKID STEER (A50458)
2019 CATERPILLAR...
2017 CATERPILLAR 289D SKID STEER (A50458)
2017 CATERPILLAR...
