broken FEL arm to bucket attachment pin
   / broken FEL arm to bucket attachment pin #1
kw22614
Platinum Member
Manassas, VA
Kubota BX1860
Hey all!!
Kubota BX 1860 - my little princess, went up against some big ole chunks of firewood logs. She won but in the process broke one of the attachment pins where one of the FEL arms connects to the bucket. It's just a pin of HARD steel about 3/4" diameter and 4&1/2" long with a hole thru one end to secure with a bolt & lock nut.
Does anyone know where I can find these or what they're even really called? I couldn't find a listing anywhere.
Got lots more firewood to process and I only just started, need one ASAP. Thanks
   / broken FEL arm to bucket attachment pin #2
May want to check the loader.
   / broken FEL arm to bucket attachment pin #3
   / broken FEL arm to bucket attachment pin #4
If it's the type of pin I'm thinking of, I don't see how you could break it without breaking something else.
thanks - tried Messicks, TSC, amazon. even google - no listings found. Are theses shear pins?
Checked loader and those pins aren't on the parts list diagram, I assume they're just 'replacement hardware'.
Does anyone know what they are actually called - guessing it would make looking them up and finding some bunches easier!
Partly my fault, haha, overloaded the fel and bucket limits by 'alot' and looks like it's been a while since last greased.
Nothing like catching up instead of making progress.
Dealer closed so I'll have to wait for the morning to actually call and talk to someone.
I found it!! Will pick up or order tomorrow depending if in stock at my dealer.
Thanks for all your reply's and concern.
Will be back at that stack of logs soon. CHEERS!
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2008 Chevrolet Impala Sedan (A55758)
2008 Chevrolet...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2016 Ford Fusion S Sedan (A55758)
2016 Ford Fusion S...
