Broken Belt
   / Broken Belt #1
yooperdave
Veteran Member
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
The Toolcat was overheating after 5 minutes of light use and shutting down on its own.
I was lucky enough to get the Toolcat back inside the shed after letting it cool down.
The next morning a small belt was laying on the ground under the engine.
I was able to get a replacement belt, but was wondering how hard is it going to be to reinstall?
The old belt was 13+ years old, and the auto parts dealer was impressed at how it held up.
I am assuming the belt has something to do with the fan to cool the radiator.
Any helpful hints and/or insights are appreciated.
TIA
Yooper Dave
   / Broken Belt #2
I don't know what model Toolcat you have but on my 'D' series (and later) the fan is hydraulically driven and it's divorced from the motor. It sounds like the belt that drives the alternator & water pump snapped on you. That's why the engine temps went up.
DEFWPO
   / Broken Belt #3
not a clue about your unit at all.
there most likely an "idler pulley" (pulley on a spring), you might need a "breaker bar" to put into center of pulley of the idler pulley and then pull the idler over, to then slip the belt on.
they do sell "idler pulley" bars at some automotive stores, that are "thinner" vs a "breaker bar" for socket wrenches. so folks can squeeze the bar down in between radiators and all the other crud in vehicles.
to note it, you are not "undoing" a nut on the idler pulley to take the pulley off, you are simply putting end of breaker bar into center of pulley, and pulling the pulley over (pulling against the spring).
on old belt little riding lawn mowers and like. a large screw driver been used by me. but you can easily damage belts doing that.
   / Broken Belt
I thought I provided a pretty good hint with the age of the belt. I have an 'A' series.
Regards,
Yooper Dave
   / Broken Belt
Got lucky - a 10 minute fix. The back box was already raised, so there was only 2 bolts to remove a cover plate, and 1 bolt to loosen the alternator.
The Toolcat once again works as hoped.
Yooper Dave
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
Terms and Conditions (A47384)
Terms and...
2014 MACK CXU613 (A50854)
2014 MACK CXU613...
1986 VIM TACK TANKER TRAILER (A50854)
1986 VIM TACK...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
