brokeintexas
/ brokeintexas #1
brokeintexas
Branson 3510
I'm looking for a place maybe an insurance,or simular that might have salvage parts for a Branson 3510 eengine model AN1700N2 I need a cranksft
/ brokeintexas #2
Hi, If your crank has bad journals you might look at having it repaired. I used to do that type of work back it the 60's. Look for a shop that does Spray Welding. They can Spray it and turn it back to the standard size. We used this on many cars trucks and race cars and it is better than new. Good Luck!
/ brokeintexas #3
As long as it isn't broken then take it to a machine shop. They can turn the crank or send it out. I just had one done for my Welder/Generator. Of course you will have to get new bearings but that would have been regardless of the repair. I'm sure you already know not to reuse bearings. BTW; cost is not as bad as buying a new crank i.e. $78 to turn, $500 to replace.
Good luck.
/ brokeintexas #4
But why do you need a crank? Lost the oil pump? Ran out of oil? Someone sabotaged it? Just curious.
Jim
JOHN DEERE 1700 - 6R VACUUM PLANTER (A63291)
JOHN DEERE 1700 -...
1995 John Deere 7400 (A60462)
1995 John Deere...
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
