Broke Down and needing advise
   / Broke Down and needing advise #1
IRTEXN
Bronze Member
Cut -N- Shoot Texas
'02 JD 4110 HST
Hey guys, I need some help!!! I was brushogging with my 4110 down a fence line....nothing heavy, just underbrush. I stopped and shut down the tractor to get off and walk an area for anything I didn't want to run over. When I went back to the tractor, she wouldn't hit a lick. Battery is good, and all the dash llights come on when I turn the key, but it won't crank. acts like it's still in gear, but it's not and the PTO isn't engaged. Is there a way to bypass all these lock outs so I can get it started and up on a trailer and to the dealer. It's a HST by the way. I'd appreciate any advise ro solutions
Howard /forums/images/graemlins/confused.gif
   / Broke Down and needing advise #2
Try pressing the hydo pedals forward and backwards to make sure they are in neutral. This has been the case before. Also when you have been running the tractor for long periods of time it is easier on the engine if you give it a minute to cool down at idle. It helps prevent heat buildup.
Nick
   / Broke Down and needing advise #3
Yes. Keep the key in the start position and jiggle anything that has a safety attached to it....PTO, hydro, etc. Has to be a safety switch that is open...................
   / Broke Down and needing advise #4
And looked for a snagged wire especially under the floor....
   / Broke Down and needing advise #5
Howard, If all the other suggestions dont work you have a bad sensor. I Dont have your model and I dont remember exactly what but I remember a few other strands where this happened to other guys. Dave
   / Broke Down and needing advise #6
I have a 4400 and when one of the various safety switches is not in the proper position, the engine still cranks, but it won't start. So unless the newer models shut down the starter motor (which is possible) I would look at either the battery or starter. If newer models do shut down the starter, then I would vote for a safety switch also.
2007 Freightliner School Bus (RUNS) (TITLE) (A50774)
2007 Freightliner...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
Woods RM660 3pt. Finish Mower (A50774)
Woods RM660 3pt...
