Brimar tailgate cost ?
/ Brimar tailgate cost ? #1
FritzII
Washington, Pa.
McCormick CT36HST w/FEL, Kubota G2160
I bought a used 6 x 10 Brimar Dump Trailer and the tailgate is bent ( bowed ) somewhat. ( Pick-up truck style gate ) It doesn't fit tight at the lower edge. The previous owner had run it over with a tracked machine while it was laying on the ground.
Can someone tell me what one of the gates might cost ? I'm not sure if I want to replace it and I'm afraid of having a heart attack when I stop at the dealers place and ask about one.
It probably doesn't matter but the gate is black.
I'm glad I bought the trailer. I have already hauled around 30 loads with it. When spring hits I'll probably add another 30 to it.
Thanx for the info !!!
/ Brimar tailgate cost ? #2
I think that I'd try to place it on the ground and run over it with the truck to straighten it again.
My poor little 5 X 8 Bri-Mar has been catching it since I bought it the end of August, almost 2,000 miles loaded, 24 loads of crushed rock at 55 total tons, 6 loads of pea gravel at 13 total tons, 20 loads of fill dirt at 45 total tons, and one 6,000# load of mortar sand. I put out almost $1,050 in load and fuel with almost $700 of that sold to people here. The rest is on my lots and I still have a bit more to haul in.
My tail gate is loose enough that the pea gravel will drop out if I kick the gate. I know that the gravel is also coming out when I hit bumps in the road so I made a set of gaskets to slip in the gaps in the gate and it seals tight now.
Good Luck with your gate.
I don't think the truck will straighten the gate but you got me thinkin'. I could yank it off the trailer and try to run it over with the loaded trailer. I don't think it will fix it though but it's worth a try.
I have hauled somewhere between 130 to 150 tons so far.
/ Brimar tailgate cost ? #4
Can you post a pic?
If it still fit's "on the trailer" I cannot imagine having to replace it.
Have any freinds with a body shop?
I just bought myself a digital camera for Chritmas but I'm not allowed to open it yet. :D
It's not too bad, but it looks pretty beat up. I'll take a look at it. I do have a friend that works in a body shop. Could probably peel off the covering and straighten the structure and recover it.
It's not bad enough to worry about yet but it may get worse with use.
/ Brimar tailgate cost ? #6
I guess if it is anything like my dump trailer tailgate, I think some good 4 X 4 blocks and some well placed sledge hammer hits would go a long way towards putting it back somewhat straight, or at least straight enough.
/ Brimar tailgate cost ? #7
Many years ago I straightened the front frame on my daughters SUV by chaining it to a section of abandon railroad track and jacking it with a 25 ton bottle jack. Just a thought....
This would definately fix them problem !!!!
I think I'm going to try this method first. I have some heavy wall pipe laying around and some telephone poles. One of these may substitute for the steel rail.
Thanx for all the options guys !!!!
/ Brimar tailgate cost ? #9
If that doesn't work..... i'd probably take it to a steel fab shop. They can probably straighten/reinforce it cheaper than a dealer can sell you a new OEM tailgate.
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
