Bright lights!!!
   / Bright lights!!! #1
Reyer Farms
Platinum Member
Lena, ms
Mahindra 5010
Has anyone added lights to their tractor? I have cab with tint and looking for bright ideas on the subject. I want the most light with least resistance.
Thanks,
Jody
   / Bright lights!!! #2
You can't wrong with LED's , mounted singularly or in a light bar & the low power consumption allows many to be fitted.....we use them as "field" lights on tractors, harvester & trucks....the key is to mount them high on the cab/ROPS so they're focussed on the work area & to minimise light reflecting or "bouncing" from the machine.
   / Bright lights!!! #3
Ditto on the LED work lamps and mounting them high ... They have come down quite a bit on EBAY since I bought mine. The 27 watts are real bright and 'resonably' priced. They make brighter ones now, that's why the 27w's are cheaper now. Here is a link to my post... and if you do a search... you will find lot's more info... http://www.tractorbynet.com/forums/customization/232356-rops-led-work-lights.html
   / Bright lights!!! #4
If you want to see some super bright LED lighting follow this thread.
I'm thinking of adding one of these myself.
   / Bright lights!!!
Thank y'all.
   / Bright lights!!! #6
I'v done LED and HID lights from tractor help.com and have had great luck. As I like to say, within 100' of any direction of my tractor, it's daytime. Flowers bloom. Birds sing. haha
   / Bright lights!!! #7
Thanks,
Jody
I think you will find an answer to your question here: LED LIGHTING REVIEW
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
Bush Hog PT 10' Mower (A50120)
Bush Hog PT 10'...
Bad Boy Zero Turn **Does Not Run** (A50121)
Bad Boy Zero Turn...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
John Deere 4040 Tractor (RUNS) (A50774)
John Deere 4040...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
