Briggs regulator
/ Briggs regulator #1
cbraig
Coopersburg, Pa.
Husky
On Craftsman lawn tractor 917.28925 with B&S 445677 - 2188 G1 engine, does anyone know where they hid the regulator?
Chris Braig
Coopersburg, Pa.
/ Briggs regulator #2
I'm assuming you mean the alternator. It is underneath the flywheel.
/ Briggs regulator #3
That model doesn't have a regulator. You have the "dual circuit" alternator (under the flywheel), which is an unregulated charging system. One of the wires coming off the alternator has a diode installed to only let 12v+ come through (red wire) and is for charging the battery. The other wire (black wire) is 12v AC for head lights.
/ Briggs regulator
Thanks all who replied. orangeandgreen is right, we have found no regulator, although the parts list for the unit does show one, probably for an earlier model. Our problem, unsteady charging voltage, appears to have been caused by a bad connection just past the diode orangeandgreen refers to. Other past issues with this tractor make me suspect it was assembled at 4:30 on a Friday.
Chris Braig
Coopersburg, Pa.
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2022 Honda Ridgeline AWD Crew Cab Pickup Truck (A64556)
2022 Honda...
2022 EZ-GO ELITE...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
2005 GENIE S-45 TELESCOPIC BOOM LIFT (A65053)
2005 GENIE S-45...
