Briggs 284707-1026-e1, cranks, wont fire.
   / Briggs 284707-1026-e1, cranks, wont fire. #1
sdkid
Was running great and then I shut it off. went to start it a few days later. Noticed the ground cable came off the block(my fault, left the bolt loose). Hooked it up and now cranks, but no spark. Pulled the flywheel and found the alt stator has a couple hot spots. Does the coil fire from the alt stator or should I look to the coil? Is there a way to test the coil?
Any help is appreciated.
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2017 Mitsubishi Outlander (A53424)
2017 Mitsubishi...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
