Breaker point eliminator
   / Breaker point eliminator #1
TOMLESCOEQUIP
Platinum Member
Strasburg, OH
A friend has a verticle shaft briggs (single cylinder) in a simplicity lawn tractor that seems to eat points. I know they used to make a small unit that mounted outside on the fan/flywheel cover and connected to the wire coming from the coil that converted small engines to electronic ignition. Are these still available, and do they work ?? Seems like they cost less then $20 when I last saw them..........Tom
   / Breaker point eliminator #2
Tom
Putting electronic ignition may solve problem. If points are going bad the same thing could happen to the electronic system. Has the condenser been changed on the engine. Also check for good ground.
Here is a link to an Ebay site that sells the kit. Don't know if it will fit your friends engine. Click Here
   / Breaker point eliminator #3
I have seen one that uses the points to operate an otherwise solid state system. It makes the points last longer by greatly decreasing the current in them. I can't remember where I saw it.
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Bucket Truck (A51692)
2013 International...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
Front Axle and Engine (A51692)
Front Axle and...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
