Breakaway Battery
   / Breakaway Battery #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
How often do you replace yours? Mine is a 12v 5.0ah battery that gets towed about 30 times during the spring and summer. I try to remember to replace it every 2 years.
   / Breakaway Battery #2
I don't have a trailer of course, but i wonder if you have ever put one of those little 1.5 watt solar chargers on it, to make it last much longer. I think I would. I used to have to replace my little JD lawn tractors batterys every 2 or 3 years. It has been several years now on this last one since I put the solar charger on
   / Breakaway Battery #3
When need. The DOT rules state it must hold the trailer brakes locked for 15 minutes.
I check mine from time to time.
Chris
   / Breakaway Battery #4
Its part of the state inspection around these parts...My neighbors lasted about 8 years with limited use--Your mileage may vary.
   / Breakaway Battery
The lid to the battery box flops around so I tie it down with a zip tie, which makes it a hassle to charge it. Besides, I think the truck juices it up a little when it is running. I bring the battery into the heated garage for the winter and put a 1.5 amp charger on it at the beginning and end of winter.
I don't have any way of checking to determine if it is in good shape or not so I just replace it.
   / Breakaway Battery #6
The lid to the battery box flops around so I tie it down with a zip tie, which makes it a hassle to charge it. Besides, I think the truck juices it up a little when it is running. I bring the battery into the heated garage for the winter and put a 1.5 amp charger on it at the beginning and end of winter. I don't have any way of checking to determine if it is in good shape or not so I just replace it.
They are cheap. I order them to my door for under $15
Chris
   / Breakaway Battery #9
I tow my equipment trailer over the road only a couple of times a year. Mostly used onsite. Rather than trying to maintain break away batteries on a little used trailer, I made a small cradle on the tongue and use my starter pack and clamp it to permanently mounted breakaway terminals. It takes about 10 seconds to drop the pack in the cradle and hook the clamps to the terminals. Since I always keep the pack charged it's a no fail no brainer.
   / Breakaway Battery #10
Good idea, OREZOK. Just lock it so it does not go missing when you stop somewhere for lunch.
Anyone use those new Lithium-Ion starter packs? They have come way down in price and are small and light.
I also get the above batteries for only $15 each total, tho I go for the 1280s, which are 7.5 A-hr.
BUSH HOG 2820 LOT NUMBER 128 (A53084)
BUSH HOG 2820 LOT...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2016 MACK CXU613 SLEEPER TRUCK (A52576)
2016 MACK CXU613...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
