Brazing copper
   / Brazing copper #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Anybody know how to braze copper pipe? Can I use a plumbing mapp torch or does it need to be a pencil tip? Rod and flux to use?
   / Brazing copper #2
I think you can get phosphor bronze filler from plumbing supply places.
It needs no flux, but you need to get the copper hot enough. I think you could do it with MAPP if it's not too big. Air-acetylene or oxy-acetylene if you need more heat on larger workpieces.
I think you could also use flux coated brass filler. Not sure what process needs more heat.
   / Brazing copper #3
Back in the 70s, I used "silver solder" for copper pipes used for liquid nitrogen. This
type of brazing required higher temps, so we all used oxy/acetylene. MAPP gas
would probably work if your pipes are not big. We did not have it back then.
Acetylene/air would also work, like plumbers often use.
   / Brazing copper #4
I used the silver solder also on brass stainless and sometimes copper. It's expensive since it really is made partly at least from silver.Use a paste type flux and go easy on the heat. If you scorch the metal it will turn black and you'll have to clean it to get the silver to stick to it. Silver solder is like braze but is thinner and will get down into the joint better.
   / Brazing copper
Ever try the brazing rings? I need braze a bunch of 1/2" copper for gas use. I'll have to check to see if the fitting are all copper. There might be a brass one which looks like it would need a flux.
Videos | Sil-Fos
Sil-Fos® (Silvaloy®) | Sil-Fos
   / Brazing copper #7
No I have not done any work on rings.
Copper is pretty soft for gas (Gasoline I take it) and can crack easily with vibration and start fires, You are much better off with steel fuel line. What is this for?
   / Brazing copper
Not gasoline, propane. I'm making some light fixtures for my off grid cabin.
   / Brazing copper #9
I used silver solder with 40 to 50% silver content to braze the copper pipe in the floor for radiant heat in a house I built. It flows at a lower temp than the lower percentage. Shine the copper up with emery cloth and use the proper flux. Heat to a dull red. works every time. I had no leaks in dozens of joints.
   / Brazing copper #10
Back in the day, just used bare bronze rods & cast iron flux with an oxy/acetylene rig with instrument tips for brazing just about anything/everything. Worked fine with copper, bronze, steel, etc. Just pick a rod size that will flow before the copper melts apart :) Was doing a lot of "found art" for pocket money (was a young & in school) but also used that combo for fair amount of fabrication & repair when other options weren't available. A good, "low temp" brazing job can be pretty strong.
Nick
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
