Brave 24 ton log splitter with a leaking cylinder
   / Brave 24 ton log splitter with a leaking cylinder #1
Dongerosa
Bronze Member
wellington ohio
7510 bota...RTV 900
I have a 30 year old 24 ton Brave unit that has a pretty bad cylinder leak. Has anyone rebuilt the cylinder? :( If yes, were do I get parts?
   / Brave 24 ton log splitter with a leaking cylinder #2
My father in law has the same unit about that year. Brave is still in business so you could go that route, just look them up on the net. I take all my cylinders to the local hydro shop when I get the seals and they put them in and ops check it for $25. Money well spent since I have torn up new seals trying it myself.
Chris
   / Brave 24 ton log splitter with a leaking cylinder #3
Most of the hydraulic cylinders use farely common seals available at local hydraulic shop by matching with the old ones, or even by measuring the piston and gland nut grooves and ram diameter and cylinder bore.
Ken
   / Brave 24 ton log splitter with a leaking cylinder #4
I just bought one. Says Brave Big Chief seller said it was 24 ton. Do you have a manual to it? 8hp Briggs real low to the ground horizontal type. Anything you can tell me about it will help.
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
UNUSED AGT 3 PT 82" ROTARY TILLER (A51248)
UNUSED AGT 3 PT...
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
Manac Walking Floor Trailer (A50322)
Manac Walking...
