Brason 5520ch
   / Brason 5520ch #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
On the rear axle, the shaft that comes out the side to the wheel leaks. Im no mechanic, so does anybody know if the rear of the tractor has to be all taken apart or is it a simple seal that just get popped in and out? Thanks
   / Brason 5520ch #2
Not sure I understand which seal you're referring to?
Do you happen to have a picture?
   / Brason 5520ch
I cant get pictures to load. The rear wheel attached to the shaft that goes into tge axle. Where the axle meets the rear housing it leaks.
   / Brason 5520ch #4
You have to pull the axle to change the seal....
   / Brason 5520ch
Is that a major project? Im going have the dealer do it. Just dont want half the machine torn apart since it only has 60hr on it
   / Brason 5520ch #6
No not to bad did it just start leaking or did something get wrapped around the axle..
   / Brason 5520ch
I think its been leaking. Ive cleaned it a few times and after running it always has some oil on the rag. Not alot of oil.
   / Brason 5520ch #8
If its under warranty I would not worry about it the dealer will fix it ...
   / Brason 5520ch #9
ON my mahindra 2810 the rear axle seal started leaking at about 800 hrs. cost me 350 bucks to fix.Had a farm mechanic shop do the work.
   / Brason 5520ch #10
Won't take a whole tractor teardown. Dealer should be able to pull the rear wheel, and then get at it from just pulling the rear axle/hub out of the housing.
Can't see it taking a whole day if he's got the parts sitting there before he starts.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2022 NORSTAR (A52472)
