Branson tractor maintenance
   / Branson tractor maintenance #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
Every 300 hr is a long time to remember not to put a funnel in where the hydrostatic fluid goes and then pour from the 5 gallon bucket.
The last time I did that I had as mess on the floor as the air can't escape the compartment. Yesterday the same thing about a half gallon of oil on the floor.
Next time I do an oil change it will be the same most likely. If in the event I do remember this, is there a faster way to get the oil in rather then using a 1lb margarine container?
   / Branson tractor maintenance #2
I just did this. Huge funnel, looked something like this one but not sure if it's the same. If you have any other fill port (my Kubota has one on the transmission between your legs, and one with vent by the 3-point top link) open that too.
The only issue I had was pouring the old stuff back into the 5-gallon bucket. To speed things up (plus it was cold), I inserted the funnel along with a steel rod between the funnel neck and the opening on the 5 gallon bucket, which allowed air to escape... greatly speeding up the process. You could do the same on the tractor.
2016 WABASH RFALHSA 53FT REEFER TRAILER (A54607)
2016 WABASH...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2007 CHEVROLET C7500 BUCKET TRUCK (A51406)
2007 CHEVROLET...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
UNUSED XSTAR 300 GALLON PORTABLE FUEL TANK (A54756)
UNUSED XSTAR 300...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
