Branson Shifting fork replacement
/ Branson Shifting fork replacement #1
nearsandiego
obrien oregon
branson 2400
Branson 2400 (Kukje) shifting fork replacement / problem?
I have a Branson 2400 that apparently has a shiifting fork issue. It will not shift into the lowrange and will occasionall pop out of the high range. Reverse will work but sounds terrible under strain. Branson customer service is non-existent and the local dealer went out of business. Is it possible to inspect and or replace the fork without removing the transmission? Is there a repair manual available? Who can I get replacement parts from? My tractor appears to work ok in the high range 1, 2 3, gears.......will it cause more damage to continue using it till I can figure out how to repair it? Thanks a Million in
/ Branson Shifting fork replacement #2
I don't know if your Branson is similar, but I can tell you about my Jinma. The cover to the transmission is held on by four bolts, you can lift it off for inspection easily. I broke a shift fork and it was maybe a 20 minute job to replace it. The cover is above the oil line so you don't have to drain the oil, and unless you really mess up the gasket you don't have to replace it.
If there are broken pieces in the transmission they can really cause problems if you run it without removing them.
/ Branson Shifting fork replacement #3
Branson is not Chinese, its Korean I belive, perhaps Japanese. Its the same as Century so check that out.
Chris
/ Branson Shifting fork replacement #4
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
GENIE AWP-36S MAN LIFT (A60736)
GENIE AWP-36S MAN...
2017 Ford F-350 Flatbed Truck, VIN # 1FD8W3G66HEB73643 (A61165)
2017 Ford F-350...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
Attention (A57148)
Attention (A57148)
