Branson loader/backhoe questions...
   / Branson loader/backhoe questions... #1
Vineyard Dave
Currently Utah, moving back to Illinois soon.
Still shopping. Seriously looking at a Branson 4720h.
Just a quick question.
Are the Branson 4720 and the 5530 able to use the same FEL and backhoe? Not that I can afford two tractor right now, but down the road I can see the advantage of having both tractors. If I'd be able to swap the loader/backhoe to either unit, I think that'd be a good thing...
Just wondering.
   / Branson loader/backhoe questions... #2
hello i am sad to tell you that this are two different series tractors so no it will not work.
After a bit more digging on my part that's what I was thinking anyway. Oh well.. like I said, I can't afford two tractors at the moment anyway. Thanks for the reply Builder.
   / Branson loader/backhoe questions... #4
The backhoe is Amerequip, and the loader is Ansung. You might check the specs at the manufacturer's websites for the dimensions. The 5530 uses the same engine as the 4720 (albeit with turbo). I sometimes get the impression while using it that the 20-series hoe on my 4720 is about as big a hoe as can go on that series, even if it is subframe mounted. It's a big hoe to swing with a ~5000 lb tractor.
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53473)
John Deere 6105E...
