Oil & Fuel Branson fuel gauge fixed ! Well, maybe...
   / Branson fuel gauge fixed ! Well, maybe... #1
Cattech
Like most people, I'm tired of the hoky fuel gauge readings which seem to follow no rhyme or reason. So I took up the floorboards and played around a bit with the vents. Basically, it has a weird arrangement.
The left side tank (non-filler) is vented through a hose and orifice and contains sender for the gauge. The right side has the filler and also accepts the fuel return from the injection rail. I didn't measure it, but most CAT engines (with which I'm very familiar) that use this type of indirect injection recirc a large amount of fuel- something like 80% of the lift pump total for injector cooling. The two tanks are connected by a 1 inch hose and a smaller 5/16 suction hose that is t'ed to the fuel pump. In theory, if the left side vent works then the two tanks should equalize through the connecting hose. But in short, they don't.
So I decided to swap them. Routing instead the return to the left tank and venting the right (which it doesn't really need since the cap is vented). Guess what, within 20 minutes of running the level stabilized and now tracks just like any auto fuel gauge. I'm still perplexed since this shouldn't have worked. But it sure did.
My guess is it has something to do with the left tank vent not relieving properly and preventing fuel flow into the tank. With this new setup, it is constantly being refilled by the recirc line and then flowing out to the right tank.
Can someone else try this and see if it works for them?
   / Branson fuel gauge fixed ! Well, maybe... #2
Interesting concept.
I guess I never let the damnable fuel gauge bother me that much. I know that I should dump in a can of fuel every 10-15 hours of operation...
I don't know much about fuel systems in general, so probably will not be messing with mine, but I'd be interested in the experience of others who've tried this...
What tractor do you have???
   / Branson fuel gauge fixed ! Well, maybe... #3
I'll check this out. My gauge problem was more electronic, but it still bothers me.
What kind of electronic problem did you experience?
To the previous question - 2007 model 4220i
   / Branson fuel gauge fixed ! Well, maybe... #6
I have a 2003 Century 2535 with a 35hp motor. My fuel gauge stoped working porperly a few years ago. It's not consistant, and sometimes it reads the actual amount, or it reads empty. I have to be careful on the empty reading because I don't know how much is in there. I usually top it off before using it, but one time I ran out of fuel because I wasn't sure what was in there and wanted to mow for an hour before dark. My mistake.
I didn't know that others were having fuel gauge issues. Does my problem sound similar to yours? I'd love to fix it and know how much fuel I have in there, but hate the idea of chasing gremlens to find it.
One problem that I did fix was the fuel lines rotting out on me. They just got really soft, and developed multiple leaks. I didn't realize this because the leaks only happen under pressure when it's running. With the bad fuel gauge, I thought I was going through allot of fuel, but didn't realize that I had a leak.
Thanks for the tip, I might give it a try.
Edde
2020 JOHN DEERE R4023 LOT IDENTIFIER 250 (A53084)
2020 JOHN DEERE...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2025 AGT M-BKM (A50123)
2025 AGT M-BKM...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
