BRANSON F4350-Farm Diesel Tractor
   / BRANSON F4350-Farm Diesel Tractor #1
papa1
HELP!!
I have a Branson F4350 Diesel Tractor-2001 that I purchased
new in 2002. I have used the Tractor a bit on my four acres, has low hours of use, and I have not overworked in any sense.
All of a sudden, the Tractor has extremely LOW pulling power,
lots of Engine trottle, Engine sounds great, no misses, no Engine noises, no Transmission noises of any kind, and the
Hydralics-bucket and back PTO lift, all work OK-lots of
lifting power. The oils are OK, and to correct levels. Once
the Hydralic/Transmission fluid was very low and I did add some Gear oil by mistake. WHAT IS GOING ON?? Would sure
appreciate some trouble shooting advice and comments on how to FIX!! By the way, No Branson Dealers anywhere near.
Phil Miera
Ccrrales, NM
noises, no Transmission noises of any kind. The
   / BRANSON F4350-Farm Diesel Tractor #2
Phil, when you start pulling a load do your rpm's drop? Or do they stay the same and your tractor forward motion slows down? IF that is happening, you could have a clutch that needs adjustment or it may be going bad. Does the clutch pedal move normally with good resistance? Willie Jones
   / BRANSON F4350-Farm Diesel Tractor #3
Is the engine RPM racing when you mention no pulling power ? If so it is possible that it could be the clutch, if not try a new fuel filter unless it is a fresh one, If you do replace the fuel filter, Poor the excess fuel thats in the bowl into a glass and let it settle to look for water. Just a few things to check out - Good luck
   / BRANSON F4350-Farm Diesel Tractor #4
How much gear oil did you add and have you ever drained it or changed you filters?
   / BRANSON F4350-Farm Diesel Tractor #5
Will it roll freely on a down grade ?
If not try to find out what is dragging, e.g. brakes set to "park" (-:
Seriously, if it will lift but not pull I'd be looking for something dragging - which COULD BE brakes.
THANKS! Did as you suggested, checked the Clutch, adjusted the linkage, and that did it. Have pulling to maybe 45 horses,
like the tractor specs say!! Thanks for the advice.
Papa1
THANKS, did as you suggested, adjusted the Clutch linkage,
and that did it. Have pulling power to spare, now!
Papa1
Thanks for reponding, turned out that the Clutch required
adjusting. Now, have pulling power to spare.
Papa1
FRONTIER CA2072 LOT NUMBER 40 (A53084)
FRONTIER CA2072...
JOHN DEERE LOT NUMBER 153 (A53084)
JOHN DEERE LOT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
